Displays the identities in the identity manager greylist.
N/A.
Use this command to display the identities in the identity manager greylist.
* Switch.94 # show identity-management greylist --------------------------------------------- Type GreyList Entry --------------------------------------------- User june@mydomain.com User Richard@corp.acme.com --------------------------------------------- > indicates entry value truncated past 35 characters Number of GreyList Entries : 2
This command was first available in ExtremeXOS 15.1.
